phonedave
- May 30, 2012
- 2,276
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
The ratchet straps and pallet wrap sound perfect.. I assume pallet wrap the top to bottom (as far down as possible) and then ratchet straps to hold that all down? I havent used ratchet straps - would they dig into the corner of the cover and damage it as it is ratched down?
The concrete anchors - challenge would indeed be figuring out how to make them flush, looks like a higher risk accident / liability concern than the wind issue... also I would need to be sure the concrete had the higher psi rating... I can check on that.
Thanks!
As long as you don't crank the life out of the ratchet straps it should be fine, just get them snug
I think you only need to go a foot below the edge of the top with the wrap. In my mind it is to seal the edge so that wind does not get under your cover and lift it up.
You could put the Red Head anchors about 3 inches away from the edge of your tub on each side and then put a eye bolt into each one (where you can hook in your ratchet strap). You could then build a box, or an angled piece of trim out of composite decking that would cover the eyebolts so nobody trips on them (or just leave them, they are so close to the tub they should not be a tripping hazard). When you need to use the eyebolts, just remove the trim
