How often do you replace the wall side, vacuum hoses? Pump o ring, and cartridge cover o rings? We are on year 4 of our pool. Hubby thinks its too soon, I want prevention!
I clean and lube my o rings every year and only replace when the are too stretched or broke... going on 8 years and only replaced the lid o ring because I got a new one in the rebuild kit when I changed motors..
As for the vacuum hoses after a some years the UV will get to them and need replacing once they start getting leaks.. I started hearing suction leaks and bought a new set... I replaced the ones that needed it, if they were still good I left them in...
