So I received my Circupool SWG and test kit on Monday. I was floored that my ppm was 7000! I used liquid chlorine for a long time now. Off to the rental store, got a pump, and had to drain nearly 50% of my pool (in phases - drain / fill / drain / fill - to ensure I didn't damage the gunite). After 3 sessions I finally got the salt level down to around 3500, the ideal level for the SWG.
I am in for a shock when I receive next month's water bill
Finally got the system installed, up and running today. A few questions for those experts out there that run this system:
- I wouldn't think so - but does the flow direction of the SWG cell matter? I don't recall seeing an arrow on the device. I put it with the cord downstream of the flow.
- The system appears to be working, but for some odd reason the current reading on the controller is showing negative 5A. The manual stated something about it running a diagnostic when starting up for 5 min, but after that it should run normally. I can't seem to get it to display a positive 5A reading.
