Hole in Gunite
jm,
Almost all the gunite pools I have seen being built had a hole or two in the bottom, just to make sure the shell did not float. Filling with plaster is a pretty standard way to do it...
There will be plenty of things to worry about, but that is not one of them... :mrgreen:
That should be patched with hydraulic cement. The hole looks too deep to fill with plaster. Plaster should not be more then 3 inches maximum.
The plaster crew can probably fill it.
jm,
So that is not the typical hole I see in the bottom of pools.. That hole is because they screwed up and had to move the plumbing..
I agree with Allen, the plaster crew will probably fill it with Hydraulic Cement and then plaster over that..
