Scott, always happy to clarify anything I've said 8)
I'll set up a hypothetical situation for this -- you want an 8' deep pool so you can have a diving board, but while digging they hit water at ~7' 10" -- in this case you could run the pump as I said and still be able to install the floor and liner 'trouble free'
. However, if you hit water at 6' 6" you would want to either install a 'well point' (a gravel filled hole next to the pool with a sump pump in it deeper than the bottom of the pool, to keep the water at bay ~constantly)
or decide that it's not worth installing the well point and pump and go with a shallower pool (a 'sport pool' is one in which the floor level is shallow enough for an adult to stand in at it's deepest - usually 6' max) which means you loose the diving option
Usually (~) the pool is installed when the water table is at ~ it's highest (your PB
should! know the water tables for the area), and once the pool is in and full, the weight of the pool water is enough to keep the liner from being 'pushed around' by ground water - if it was only a few inches above the floor when the pool was installed - this may mean that you don't drain any water out when winterizing the pool (it's not
muchharder to winterize a full pool, but a lot wetter for whoever is doing the winterizing :lol: ) However, if you ever experience 'record breaking' rains - the well point will help to keep the ground water from floating the liner.
The vermiculite is, by it's nature, solid yet porous - water can pass through it easily-- however, if too much water is continually passing through it, the cement in it
will wash out leaving you with nothing but mud and 'mushy' vermiculite.
