quick question. We use trichlor at work for our jaccuzi. I've been draining it once a week to keep the CYA down to below 100. Over 100 and you get shut down by the health department.
I want to keep the pH from rising fast. I drained the jaccuzi, filled it up, added acid to get the pH to 7.2. Not even an hour later, after 4 people get in the jaccuzi, the pH went up to 8.0
Since the jaccuzi was just filled with fresh water, the CYA was close to 0
If I keep the CYA at around let's say 60, would it prevent the pH from rising that fast? FC is gonna be around 5 to 7 ppm. TA is around 110.
