Hello,
We are in the process of having a 30x15x6 deep (deep end) fiberglass pool installed by an experienced contractor. Our property is very wet (right against a wetlands). They are setting the pool in the hole tomorrow.
My wife and I are concerned with the ground water under this pool. When excavating a water vein was hit and the hole is continuously being filled with water. Almost as though a garden hose was constantly coming out of the sidewall of the hole. The contractor is using pumps to keep it dry until the pool is installed.
Long term has anyone run into situations where the pump in the sump tube needs to be running 24/7? I’m not sure how high the water will go up the pool but it looks like it will be about 3’ or so. it seems like it would be a lot to have a pump running 24/7 to dewater this pool.. are there hard wired in pumps so I don’t have to keep an extension chord out all the time? At what depth should I be concerned?
I appreciate any feedback on this topic.
Thanks
Thanks
