- Sep 21, 2007
- 121
- Vinyl
- Hayward Aqua Rite (T-15)
One of our neighbors passed away this summer. Her family knows nothing about pool care, and have been relying on a pool company to maintain the pool until the estate is settled. In the past month alone, they have spent an incredible amount of $ battling an algae bloom.
After seeing my pristine pool, one of her daughters asked if I could help them out. I estimate the pool to be about 25,000 gallons, has a vinyl liner, sand filter, single speed, 1HP pump, chlorine puck feeder, without a heater. We live in Ontario, Canada and usually close the pool in mid September for the winter. The family would love to get a couple more days swimming in before closing, but that is not critical. I suspect that to keep their options open regarding sale of the property, and want to get recent pictures of a nice looking pool to demonstrate its condition to potential buyers.
The water is green, and murky, but I've seen much worse on this forum.
I measured the water with my Taylor K-2006C test kit.
pH 7.4
Cl 3
CYA ~120 (beyond upper range of my measuring scale)
TA 100
I suspect the pool company put way too much stabilized chlorine into the pool to fight the algae bloom instead of using liquid Chlorine. I was going to present the following options:
1) Partial drain and refill to lower the CYA to about 70ppm, then use SLAM method to get the pool back. Then the additional drain at closing and refill over the winter would lower CYA to less than 50, which would be manageable for next year.
2) Partial drain and close the pool,. Let the the snow fall replenish with new water over the winter. This would drop the CYA to 70-80. Which is still very high to start a season, so I would recommend using liquid chlorine for all of next year.
3) Per the CYA/Chlorine Table, SLAM the pool up to over 40ppm and then maintain the pool over 11ppm for the remainder of the year using liquid chlorine (are there other any forms of chlorine without stabilizer?).
Before I spoke to them, I thought I'd bounce these off the forum to address some of my questions, particularly:
a) During a partial drain, can I vacuum the algae to waste and send it out to the street/storm sewer?
b) Normally, I wouldn't even consider raising Cl even close to 40ppm, but this is what CYA/Cl table recommends. Does the high stabilizer reduce the impact of bleaching out the liner.
Any help would be greatly appreciated.
pH 7.4
Cl 3
TA 100
