I've got an odd situation that I can't figure out, and neither can CircuPool, so I'm looking for input from someone knowledgeable with the electrical nuances of these systems.
In a nutshell, I've tested myself, with confirmation from my local pool store, the salt level in my pool, and it's 3,200ppm. The SWG is showing a reading of 5,500, and the "high salt" light is of course blinking. I've read about the PCB issue that causes high salt readings, but it's always associated with a high voltage reading. In my case, both the current and voltage readings are well within spec, and towards the lower end of the range. As I understand it, the cell doesn't actually read the salt level in the pool, but uses current and voltage to arrive at the level. As I also understand it, as long as the current and voltage are within spec, the SWG will continue to produce chlorine, regardless of the blinking "high salt" light.
The question is, if current and voltage are in spec, how/why is the SWG displaying such a high salt reading? The cell by the way is new, and these readings came about after installing the new cell.
I'm going by the assumption that the system can't be harmed by a possible defect with the cell if all electrical readings are within spec, but the high salt reading has me baffled.
