- May 24, 2017
- 20
- Plaster
- Jandy Truclear / Ei
PB added too much salt in my new pool. Per Taylor kit, it’s 4000ppm.
Manufacturer for the Jandy TruClear SWG says target is 3000-3500.
I still need to add 64 lbs of Calcium chloride to get CH to 400 (currently 170) and need to add 14-17 lbs of CYA to bring it up from 3-5 to target of 60-70.
pH is also real high, and I’ll need to add some chlorine too. (FC 1 right now).
I am concerned that the salinity will further rise with these additions. I’d rather not have a strong salty tasting pool.
Should I pump some water out of the pool (& add fresh water) before adding in the CaCl & CYA? And idea how much to pump out?
