Hello all. My Ph is constantly high - above 8.2. Every week, I'm adding nearly a gallon of muriatic acid but when I test it again the next week, it's off that chart using the Taylor kit. The Taylor kit is brand new to replace one with expired chemicals. When I test the pool with some test strips, Ph is right in the perfect range. I know everyone says trust the test kit chemicals more than strips, but the test results for all other elements (Chlorine, CYA, hardness, alkalinity) are all very similar between the Taylor kit and the strips - only the Ph is the big outlier. I tested my tap water using both the Taylor kit and the strips. The strips and the Taylor kit were very close in this case for all the elements. Why would I get similar results between the Taylor kit and the strips testing my tap water, but such Ph extremes with the pool water?
I have a salt water pool, 21,500 gallons, pebble sheen plaster, about 8 months old. Thank you for any advice you can provide.
