I have been waiting all fall for my water temp to drop before closing .... the same thing I have done the past four or five years. During this time I get leaves in it and it turns greenish and before closing I get it cleaned up again and have had no issues when opening in the spring. I've never tested pH in the fall but it was fine every time I opened it. This year I tested pH and it was off the charts high (Chlorine was at 9ppm so high but in theory not high enough to impact pH reading).
Does this make sense? Normally my pH is very stable all summer and I may end up adding MA once if at all.
If it's normal does it make sense the pH would drop over the winter? Would the cold temp (54 degrees) make a difference?
In any case I had some MA on hand and added a bit yesterday but didn't want to overdo it
