High free chlorine
Jsf721
402
Long Island, NY
Went out today to take a look at the pool and do my water testing below are my results which I did log in pool math. I turned my generator down from 60% to 50% but I’m not sure that that’s even low enough, the chlorine was at 25 which is the highest it’s ever been but I’m new to the saltwater generator and I started out at 60%. And I’m not on site to monitor daily I’m not sure if the other test results are accurate due to the extremely high chlorine. My pool company added 1 gallon of muriatic acid this morning to lower the pH. I’m not confident that it’s been fully mixed as he only put it in about an hour ago.
Looking for suggestions on saltwater generator settings as the next time I’ll be out at this pool will be the weekend of May 17
At a FC of 25 ppm, then the pH test is invalid and no adjustments should be made.
Be ware of using pool company testing for any chemical adjustments.
Your RJ-60 will make 2ppm of chlorine a day running pump 24x7 and 20% output.
It really depends on the pool, how much it will use on a daily basis.
Is your CYA really 90?
Do this test starting at #8:
Do you use a solar cover?
Does the pool get full sunlight?
We can make a general recommendation knowing these things to get you to the 17th.
I do all my testing with the TF pro kit with salt.
My sonar acid is 90 if not 100. I never rely on Lesly‘s testing which is why I bought my own test kit and to prove to myself that there was bad as this board said they were years ago. I took the same water sample to three Lesly‘s and got three remarkedly different test results. At that point, I started drinking the Kool-Aid around here.
My pump is running 10 hours a day currently it was set at 60% and I dropped it to 50% looking for feedback on if that’s the proper percentage to leave it at I would like my free chlorine to drop into the green zone for a 90 CYA.
My pool gets full sun for about five hours a day picture taken at 3:15 and then it slowly goes out of the sun. I do not have a cover of any type. Water temperature is a little over 60°.IMG_4494.jpeg
I'm still losing / producing about 2 FC a day nearby in full sun. It's going to be mostly cloudy or raining until the 13th so you'll be losing less than 2 FC a day for most of the stretch until you're back again.
If its running 24/7 then 10% is probably good to let it drift down while still adding a little
Reactions: Jsf721
Since the pump is running 10 hours a day I set it a 25% and see how that does. Thanks for the advice.
Any equivalent maths works
Are you familiar with letting poolmath do the calcs for you ? (Upper left menu : effects of adding, swg ).
You can chose FC created, pump hours or %, once you select your model and your volume. If you enter 2 it will give you the 3rd, for example 10 hours at 25% will make X.X FC. Then you can mess with them all to find however you want to set it for next week. Maybe you want it to make 1.5 FC a day. Maybe you want it to do so in a 10 hour window. Poolmath is the bees knees here.
I am not but I will check it out.
Since May 2nd I have had my SWG on 25%. The results 5/17 are
FC 12.5
CC 0
PH 7.8
Alk 100
Salt 3800
Calcium 350
Cya is 70
So FC dropped by 50% and my CYA dropped by 20 points.
Where should I leave my salt water generator. I dropped my from 60% to 25%
10 hours per day in the RJ at 25% creates 1ppm/day.
3rd to 17th is 14 days. 25 - 12 = 13.
So about 2ppm loss per day.
Use effects of adding in pool math and figure out a % output that will give you 2ppm per day with 10 hours of runtime.
I think your demand is likely higher.
  1. Do you use a solar cover?
  2. What are the dimensions of your pool? LxW,D shallow, D deep?
FC 12.5
CC 0
PH 7.8
Alk 100
Salt 3800
Calcium 350
Cya is 70
So free chlorine dropped by 50 and cya is down to 70 from 90.
Where should I leave the swg Percentage wise ?
It did rain a lot and it’s been sunnier.
I answered this in post #15.
Sorry for the double post. Not sure why I did not see it post.
No cover at all and the pool is 20x40 and average depth estimated it 4.5 feet ?
I've been maintaining pretty even while producing 3 FC per day. There was hardly any sun last week so our pools probably behaved closer than normal.
Tomorrow is warm and sunny-ish but then its cooling off. 2ppm a day might be OK.
Reactions: PoolStored
