Lee,
CYA is there to prevent the sun from consuming all your chlorine in a few hours. 50 is as high as we like to see it in a non-saltwater pool. In saltwater pools, we like to see a CYA of 70 or 80... This time a year it is not a big deal, but as the summer gets here, if you find that you have to turn your salt cell's output way up to keep the chlorine in your pool, then I would suggest that you "slowly" bring your CYA up to 70..
What you should see is an increased demand for FC as the summer gets here. Until you get a feel for how much chlorine your pool uses, I suggest that you test every day or two and if you see your FC starting to go down below your target, then increase the cell's output. If the FC is trending up, then lower the cell's output. Keep in mind that you looking at the big picture and not just one day. You should not try to adjust on a daily basis, but on more of an average...
If you can, test at about the same time of day. The best time is just before the pump is scheduled to come on. This is because this is the time that the FC should be at its lowest level. The whole key to our process is to never let the FC fall below the minimum level shown in the CYA to FC chart.
If you have not done so already, you should take a read through our Pool School.
