Hi there everyone!
I'm a new home/pool owner and new to the thread - have been lurking around and not sure if I'm seeing anything specific to my problem so here goes... (I apologize, this is extremely long)
----Backstory----
We moved into our home a little over 4 weeks ago and the pool has been nothing but frustrating. The previous home owners had a pool inspection, which showed high CYA (in the 100's), no FC/TC, and high phos (in the 2000-3000's if I remember correctly). The water was minimally cloudy per the report but otherwise no other major findings. The previous home owners drain the pool 1/3 every year (not exactly sure what their reason is for this - maybe persistently high CYA?) and use chlorine tablets for maintenance, Shock as needed. Also, there are trees everywhere, and in pretty close proximity to the pool.
1.5 weeks after moving in, we had a pool company come out to do another inspection and for weekly maintenance since we knew nothing about owning let along maintaining a pool. Similar findings as above. A few days later, the pool turned green and our sweeper (old barracuda that came with the house) stopped functioning. The pool guys shocked the pool and replaced the barracuda with a G3 that's also not functioning - the pool is now dark green and cloudy with no sweeper. The goes on for about 1.5 weeks (they came and replaced a bunch of valves to try and trouble shoot the sweeper but couldn't figure out why it wasn't working, then tells us the sweeper is not important) so I take a sample of the water and go to Leslie's (7/24/22):
FC: 0.1ppm
TC: 0.1
pH: 7.5
TA: 131 ppm
CYA 166 ppm
Phos: 5757 ppb
TDS: 3300 ppm
I bought some supplies to shock the pool myself (power powder plus). The pool is lighter green but still cloudy. Brought a sample to Leslies (7/26/22):
FC 4.9ppm
TC: 6.01
pH 7.8
CYA 134
Copper: 0.7ppm
Phos: 6352 ppb
TDS: 3400 ppm
The pool guys come back one more time and shock the pool again and this turns the pool (3 days later) blue but it's so cloudy you couldn't see the sweeper at the bottom of the pool. They came back to clean the filter again to see if this helps (2nd filter clean in 2 weeks). The pool is looking better, but I'm noticing the FC levels creeping up (7/30/02). Also, during these periods, I have been replenishing my pool with new water.
FC: 20.51 ppm
TC: 20.51
pH: 8.1
TA: 92
CYA: 129
Copper: 0.3ppm
Phos: 4906
TDS: 2450
The pool guys wouldn't answer my questions about why the sweeper is not working so I go on to youtube and learn how to take the barracuda apart - the diaphragm was torn and clogged so i replaced it. Pool guys charge me for the barracuda at this point, and now they are fired. I added muriatic acid to bring the pH down and next day (8/2/22):
FC: 25.25
TC: 25.25
pH: 7.9
CYA: 149
Copper 0.4
Phos 4000 (out of range on their machine - but i think it was in the 6000's)
TDS: 2400
----Current problems----
The pool is now super clear but here is where I'm having issues:
- I have not added any source of chlorine (tablets, liquids, etc) since the pool was shocked by the pool guys a little over 2 weeks ago and my chlorine is still super high - it maxes out on Leslie's machine around 25ppm so I don't know if it's started off super high and is coming down slowly, if it's not changing, or if it's going up. We've been having pretty hot days in Northern California (90's) and my pool gets direct sunlight 4-5 hours out of the day. Because I'm paranoid, I used a test strip on the water that I'm filling the pool with and confirmed there's no chlorine being added. I checked the skimmer filter and cleared the debris but no tablets I could find. I bought the Taylor 2006c kit, filled to 25 ml, and had 140 drops of the reagent and the water was still light pink - I gave up at this point (at least 28ppm FC).
- CYA obviously is still high - I have a fiberglass pool. Any recommendations? I've been doing very small draining of the pool (1-2 inches at a time, fill up and let the filter run; drain another 1-2 inches the next day, fill up, etc). Is the high chlorine because of my high CYA?
- Phos is still high - I did a noPhos treatment (yea, i know, should have gone with the PR 10000) and that didn't budge the phos.
- Lastly - the last week, I noticed very well defined marks on the floor of the pool. They are dark (I think brown color) spots with clean edges, and I can't get them off with the nylon brush I have no matter how hard I scrub. They are scattered at the bottom below where the skimmer is, and where the jets are. They don't seem to be getting worse. On 8/3/22, I found one of those Pool RX baskets with Copper that the pool guys placed in my skimmer - could this be the cause of the marks? I'm unable to reach the marks to test with chlorine vs. Vit C without completely submerging myself in a pool with an unreadable chlorine level.
Last reading by Leslie's (8/5/22):
FC: 25
TC: 25
pH: 7.9
TA: 129
CYA: 144
Copper: 0.3
Phos: 5000's
TDS: 3400
Sorry for the long story, but it's been a long road - I still haven't been able to use the pool since moving in. Any advice/similar stories would be much appreciated!
----Backstory----
FC: 0.1ppm
TC: 0.1
pH: 7.5
TA: 131 ppm
CYA 166 ppm
Phos: 5757 ppb
TDS: 3300 ppm
FC 4.9ppm
TC: 6.01
pH 7.8
CYA 134
Copper: 0.7ppm
Phos: 6352 ppb
TDS: 3400 ppm
FC: 20.51 ppm
TC: 20.51
pH: 8.1
TA: 92
CYA: 129
Copper: 0.3ppm
Phos: 4906
TDS: 2450
FC: 25.25
TC: 25.25
pH: 7.9
CYA: 149
Copper 0.4
TDS: 2400
FC: 25
TC: 25
pH: 7.9
TA: 129
CYA: 144
Copper: 0.3
Phos: 5000's
TDS: 3400
