Newbie here....I have high CYA level, it's reading below the 100 mark on the Taylor 2006-C test kit. Below is the rest of my test results....
FC 5 (I understand that my goal should be much higher according to the CYA/Chlorine chart. I've been keeping it higher than this).
TA 130
CYA >100
pH 8
CH 300
My question is this. We are still probably about a month out from swimming as it isn't quite warm enough here. I understand in order to get my CYA down I will need to drain nd refill. How much should I drain? Is there any problem refilling with our well water? I haven't had our well water tested, but I do know there is iron present as you can see staining in my toilets. Should I even mess with trying to balance the chemicals before I drain? How do I go about draining? Do I leave it open to the skimmer and the main drain, but just turn the filter to "waste"? Thank you!
TA 130
CYA >100
pH 8
CH 300
