Hi, The issue with our 15 yr old IG pool is the common issue of high CYA. Today's reading using 50% diluted pool water is off the chart using Taylor 2006 kit. Only took about 3/4" of mixture to cover black dot. I now know why our CYA is high and I have read on TFP what the options are to rectify. Leaning toward a full drain, not too worried about the water table here just East of Austin, TX. I am afraid at our high levels the drain and fill simultaneously approach would take too long and too much of the water would get mixed. RO is expensive, $500-700, water < $200.
Three questions:
(1) Though I could not find mention of it on TFP, I had read somewhere that CYA will keep leaching from the plaster. Is this true and if so how much impact does this usually have?
(2) At our high levels does the plaster need to be cleaned somehow to prevent leaching?
(3) Assuming the water table is not an issue, is it generally safe to do a full drain, any plaster issues?
Thank you so much for your help!
Three questions:
