The pool is balanced except for the CYA and chlorine.
CYA - 100
FC - 0.24
TC - 0.33
Everyday there are small patches of algae, which is easily brushable and disappears.
On Thursday, I shocked with 2 bags. Next day no chlorine and patches of algae. On Friday, I shocked with 3 bags and with in 7 hours the pool had no reading of chlorine.
I know with high CYA levels you need to keep FC higher as well. How do you do that? Do you need to shock everyday and how much is needed to put in to reach that level?
I looked back to my numbers from last year and my CYA was just as high but I had chlorine readings. So I don't understand why I have the issue this year.
Is my only solution to drain the pool and refill? I don't have any place to drain the water to. We are not allowed to drain it in the street.
Any help or advice, I'd appreciate.
Thanks!
CYA - 100
FC - 0.24
TC - 0.33
Thanks!
