Hi folks! I’m new to maintaining my own hot tub and recently switched from “do what the pool store says” to TFP approach.
these are my test results
pH 7.5
FC 9
CC 0
CYA 80
CH 250
TA 80
400-500 gallon hot tub - 7 person strong spa.
Whats wierd is I’ve never put stabilizer in this water. I have put in “chlorine down” when I accidentally put too much chlorine in before I switched to TFP approach.
What could cause this high of CYA? Before I drain and refill, I want to understand the root cause so it doesn’t happen again…
Thank you!
pH 7.5
FC 9
CC 0
CYA 80
CH 250
TA 80
Thank you!
