Hi all. I'm a noobie with the TFP method. I just got my TF-100 and I recently learned the connection between CYA and FC levels. Last year I would take a sample to the pool store weekly - every 2 weeks, but everything was always within range so I stopped that about a year ago. Last summer to now I was using chlorine pucks and test strips.
I have three questions.
1. I tested my CYA level today and it was under the 100 mark on the tube (so greater than 100). Is there a way to test this to know how much > 100 the level is?
2. We are going to re-plaster the pool in 6-8 weeks. So the water is going to be drained/re-filled then. Our city water is very expensive. We are also entering rainy season in FL so some of the water will naturally turn over. What do you think of stopping the pucks and letting the CYA level come down "naturally" until we re-plaster the pool as long as we don't have any algae issues.
3. Finally, CH was 525. I would look at the "Total Hardness" on the strips and it always around 250 so I thought I was good (until now). My CSI is 0.07 according to Pool Math. Would it be ok to let this ride until we drain the pool for re-plaster? I think I have read where it should be ok because of the CSI, but I want to make sure. Also, not noticing any visible scaling issues.
Chems today for complete picture:
FC: 6 (added LC today to get to CYA/FC goal)
TC: 0.5 (maybe less. One drop turned it back to clear)
pH: 7.4
TA: 100
CH: 525
CYA: > 100
CSI: 0.07
pH: 7.4
TA: 100
CH: 525
CYA: > 100
CSI: 0.07
