High CYA. How much to drain?
Jb48560
11
San Antonio TX
Received my TF kit this week and if I did the CYA test correct I’m around 100-110. I weaned off puck use this week and suspected it would be up there. Prior I used strips and it was approaching the maroon color indicative of high Cya. I’d like to start off managing the pool
with reasonable levels of liquid chlorine. How much should I drain and what precautions should I take ? In ground pool I believe finished with pebbletec. It’s 12212 gallons in capacity I live in southern Texas it’s been hot and relatively dry lately. Thought it may be best to drain / fill late at night because of the heat. Thanks in advice for any help. I have a submersible pump and some time this weekend to tackle the chore.
Must you do this in the sun as the video suggests?
Light is important for turbidity tests. Not sure what video to which you are referring.
For CYA over 90, use this and start at #8:
Reactions: Jb48560
Thank you this article it is immensely helpful! I’ll give this another go as I made several missteps it seems in my teast. The video I am referring to is in the TF’s you tube channel. It’s not as detailed as the instructions you shared. Any tip for accessing tpool school resources? When I’m logged in to participate in the forum it does not allow me to access articles or links that you shared. If I log out all is well and I can go through this article and all the resources. I noticed this when I registered for this site again actually.
Reactions: PoolStored
Strange. If you are using PC, clear your browser cache.
jb,
In Texas, you need a CYA of about 50 in the middle of the summer.. So, I'd drain about 60 %..
Did you do the diluted test that you need to do when your CYA is 100 or over??? If not, your CYA could be well over 110..
Jim R.
Hey Jim !
I did the dilluted test as you recommended at 100 barley visible went to 90 to fully obscure the black dot ..so my calculations is 180 or 190 is my CYA reading would you change drain recommendations as far as the amount? Thanks for any help you can lend.
jb,
You can try to drain just the right amount, or you can just drain the whole darn thing and start over... :mrgreen:
If this were my pool I'd drain most of it and then immediately refill it with new water. Yes, you will have to initially add about 30 ppm of CYA, but I do not see this as a major issue.
Jim R.
Reactions: Jb48560
jb,
Jim R.
Thanks for the advice Jim I’ll be draining and refilling it this evening /through the night. I’m excited to get control of my chemicals again. So when I get it refilled test all aspects of new water first? Then balance ph alkalinity. Then I assume with new baseline measurements for all things the tf PRO kit can measure I then add the appropriate level of chlorine and then start my daily / weekly routines?
jb,
I'd want to get some Liquid Chlorine in the water first, but it will burn off pretty quickly as your CYA should be pretty low... I'd add enough CYA to get you up to 30 ppm or so.
It will take a couple of days for the CYA to start showing up in your tests.
Then start getting your pH in the 7's and your CH up if too low..
The most important part, in my mind, is to keep your FC at the target range for your CYA, no matter what the CYA is right now. And as you slowly add any new CYA..
FC/CYA Levels
Thanks
Jim R.
Reactions: Jb48560
jb,
FC/CYA Levels
Thanks
Jim R
jb,
FC/CYA Levels
Thanks
Jim R.
I drained almost all last night Maybe 6inches left in the deepest spot. Cya not showing up so assuming I accomplished lowering it. Pool math says 3.5 pounds but thinking I’ll start at 3pounds cya then remeasure in a couple days. Just added about a quart of acid to get ph in the 7s . I was shocked to see Ch was 175. San Antonio has very hard water. Pool math says 41 pounds of calcium chloride. Does this sound correct? Should I retest this again after CYA additions? TA very high at 200 as well. Hoping acid addition brings that down some. Any advice is appreciated!
