High CYA. How much to drain?
Jun 26, 2017
4
San Antonio TX
Received my TF kit this week and if I did the CYA test correct I’m around 100-110. I weaned off puck use this week and suspected it would be up there. Prior I used strips and it was approaching the maroon color indicative of high Cya. I’d like to start off managing the pool
with reasonable levels of liquid chlorine. How much should I drain and what precautions should I take ? In ground pool I believe finished with pebbletec. It’s 12212 gallons in capacity I live in southern Texas it’s been hot and relatively dry lately. Thought it may be best to drain / fill late at night because of the heat. Thanks in advice for any help. I have a submersible pump and some time this weekend to tackle the chore.
Must you do this in the sun as the video suggests?
Light is important for turbidity tests. Not sure what video to which you are referring.
For CYA over 90, use this and start at #8:
Thank you this article it is immensely helpful! I’ll give this another go as I made several missteps it seems in my teast. The video I am referring to is in the TF’s you tube channel. It’s not as detailed as the instructions you shared. Any tip for accessing tpool school resources? When I’m logged in to participate in the forum it does not allow me to access articles or links that you shared. If I log out all is well and I can go through this article and all the resources. I noticed this when I registered for this site again actually.
