Hi all,
New pool owner after purchasing house. Its a large 39k gallon chlorine pool. The pool has been blue and seemingly fine the past month and haven't added any chemicals. The prior homeowner had a weekly pool service come and manage the chemical balance.
I am in Livermore, CA with temps in the 50s/60s.
The owner left a cheap test kit and so I tested the chlorine level and it was extremely yellow/high and upon reading this forum decided to purchase the Taylor 2006K test kit as its more accurate and comprehensive.
I also wanted to test the pool because I have brown/yellow organic stains in the deep end from leaves and worms that are not fading away at all after a month even with brushing and I am told they should.
With the Taylor 2006k test kit I see:
I was surprised that FC was 4.8ppm considering how high CYA is. Curious for any thoughts. Also, it was a little discouraging that I am reading that I will need to add liquid chlorine daily in the summer to the pool to maintain good health and proper CYA levels as that just doesn't seem feasible. Makes me want to convert to saltwater by adding an SWG which is at least a bit less maintenance.
Thanks for the help!
- 4.8ppm free chlorine (25ml sample, 1 drop = 0.2ppm)
- No Combined Chlorine (Adding reagent, the sample didn't turn pink at all)
- CYA was > 100. The 9191 bottle had liquid halfway between the 14ml and 7ml mark and the black dot disappeared before the liquid even hit the 100 mark...close-ish but not there.
