Hi all,
It's been a while because things have been going good. Opened the pool to clear water, basically had to add water, salt, a tad bit of bleach and a little baking soda. Chlorine did drop way low, so set swg to run 10 hrs. Forgot. Chlorine levels had been good. Today it's 11. TA is 90, CYA is 45, salt is 2800, PH 7.5. So I shut off the swg, and reset it to 6 hrs for when I start it up again... I am "assuming", but since everything else is fairly good, did the long timer cause the high chlorine? And should I let UV kick it down or should I drain? Temp is 72, so it's supposed to be mid to high 80's all week, so that's not an issue. I know I'll have to add alittle more baking soda. TIA
Pam
6000 gal agp.
Pam
6000 gal agp.
