- Jun 24, 2021
- 16,276
- Vinyl
- CircuPool RJ-60 Plus
Yes.Is this normal?
Chlorine will degrade faster in the presence of UV and contaminates when FC is higher.
Yes.Is this normal?
Leave ph alone- it will rise on its own.So now out of SLaM and keeping normal levels. I tested this morning and my FC was 9.0 , my PH was 7.2, and my alkalinity was 80. So I think best would be to raise PH, but alkalinity is where it should be, correct.? Baking soda would raise both PH and Alkalinity. Should I just leave Ph where is or add some baking soda?
OMG that is a heck of a drop. But just to clear up any confusion, my CYA isn’t 30pmm, just that’s the lowest number on the tube. I can easily see the dot at 30ppm so it could be at 20ppm or less I guess. Tomorrow night I’ll add another 13ppm or maybe more and see where that bring me too.You're good. 13oz gets you 8.5 ppm CYA. Under 30 is sketchy at best to read. A 15, for example, might look like none or 20. You just don't know what it is until it's a solid 30. So you added 8.5 and have 30 now. All is well.
With regards to the CYA drop, it's been crazy at times here with the rain this season. We're helping someone else on LI who had 100+ CYA and is down to almost 1/3 from a few big storms and backwashing. So your drop isn't alarming at 50%.
Ahhhh. Ok. It seemed it was now 30 after the add. Give it a couple of days before adding more. It doesn't always show up right away.my CYA isn’t 30pmm, just that’s the lowest number on the tube. I can easily see the dot at 30ppm so it could be at 20ppm or less I guess.
