There are ways to reduce CH without drain and re-fill. However it is a lot of work. Also a new pool will have a high CH due to plaster curing.
Found this forum. Thank you!!!
I plan to order test kit. Found it on Amazon. We are greatly suffering from what I assume is calcium scale. We have scale on the sides of the pool, in the DE filter and in the pool heater.
I just checked and it would cost close to $1,000 to replace our water. We need to find an alternative to stopping this scale problem. We didn't realize this was occurring right away. My husband took apart our pool heater when it started popping and yes it was clogged with scale...he removed that. Our DE filter is also getting scale clumps clinging to the DE. Yikes. We've never had this.
The output where the heated water comes through actually spits out little rocks at times that look like salt.
I think the issue occurred because we filled the pool about 5 inches or so with our well water when we started it up. We don't totally drain the pool in the winter nor do we cover it with hopes that snow/rain will help refill it and at times this has worked great. This year was a more mild winter so we had to add well water. Since then we've used our water softened water to keep it filled an inch or so at a time. We also have a portable RV water softener that we've used to fill an inch or so.
I've taken our water into the local pool store and no one has ever said we had too much calcium. Our water is beautifully shiny and clear. We are now having algae problems, something we've never had before and we've had the pool for 7 years.
My husband has had to clean out the filter practically every 2 weeks or less now. We may have to replace the inner filters because they have some scale in them.
It's an 18X38 above ground pool that's 4' deep. It's in a deck that's level with the ground at one end because we have a walk out yard so the pool is not a climb up even though it's considered above ground.
It's in sun all day. We like to keep it warm - we like 89.
I'm ordering the test kit overnight from Amazon and will do the test tomorrow.
We have a Nature2 Express plus we shock about every 5 days using Smart Shock. To clear up algae we've been using liquid chlorine but even 6 gallons did not work. Pool store advised using algaecide, 4 Smart Shocks, and muriatic acid to lower the PH. We tend to be high PH. It worked but within days came back. After reading this forum, I now think we have mustard algae so going to look into that as well.
Again thanks for this forum and any help on the calcium issue would be greatly appreciated. We don't have $1,000 to replace the water!!! Yikes.
