Hi all,
I have a few things going on, hoping you can help make sure I’m on the right path.
Bought a TF-100 kit and did these tests today:
Alk: 60ppm (will raise tonight with sodium bicarbonate)
CYA: 40ppm
PH: 7.8
Chlorine: was high but I shocked yesterday
CH: 525
Last year I had my pool replastered and was using Leslie’s to help with tests. I accidentally screwed up the start up and put in way too much calcium into the pool and ever since then have been fighting scale that I can’t seem to get rid of along with chasing PH levels as the pool off gasses from the plaster.
My plan is to drain the pool to below my pool light, leaving it there for about 4-6 hours as I do some work on the light and then fill it back up again. I want to make sure that I don’t cause a ring from having the pool not completely drained or any other adverse effects on the plaster. Any tips on how to ensure I don’t screw up the plaster during this process?
Also I’m assuming this will help get my calcium hardness to an acceptable level but let me know if I’m off track
Thank you!
CYA: 40ppm
PH: 7.8
CH: 525
Thank you!
