Ok, I finally got my pool setup for the 2nd time due to some level issues. I'm trying to get my CH down, but can only find draining some of the water to be a way to lower CH. I tested my tap water and it is at 700 ppm. I thought I read somewhere that there is a flocculant you can add to the water to reduce CH. I raised my FC to 10 ppm yesterday, as advised by another member. Today it has drifted down to 7.5. The rest of my numbers are as follows:
PH- 7.4
CC- 0
CYA- 70
CH- 800
TA- 70
SI-.15
PO4- 0
Salt- 4200
Any suggestion??
Thank you in advance!
PH- 7.4
CC- 0
CYA- 70
CH- 800
TA- 70
SI-.15
PO4- 0
Salt- 4200
Any suggestion??
