High calcium hardness-should I be concerned?
Flbeachluvr
397
Port Orange, FL
#1
I usually test CL and pH daily and everything else one a month. Today's numbers:
FC: 5.5
PH: 7.5
TA: 40
CH: 590
CYA: 50
I will bring up both the TA and CYA according to Pool Math. My CH is consistently high though every time I test it even when all my other numbers are good. It has dropped from a high of 640 in March to what it is now. Here in Central Florida we are in our rainy season and I have had to drain off several inches about 2 weeks ago.
Is there any damage that could be done with a higher than recommended calcium hardness level?
Richard320
20,330
San Dimas, CA (LA County)
#4
Use a 10 ml sample for the CH test. 10 drops of R-0010, 3 of R-0011, then multiply R-0012 by 25. When you get to those kinds of numbers, whether you get 575 or 600 instead of 590 doesn't make a lot of difference but it does save a lot of drops. If the color is too faint, use more R-0011
OP
OP
Flbeachluvr
Flbeachluvr
397
Port Orange, FL
#5
Use a 10 ml sample for the CH test. 10 drops of R-0010, 3 of R-0011, then multiply R-0012 by 35. When you get to those kinds of numbers, whether you get 575 or 600 instead of 590 doesn't make a lot of difference but it does save a lot of drops. If the color is too faint, use more R-0011
Good to know! I hate using that much reagent.
JoyfulNoise
Platinum Supporter
May 23, 2015
14,704
#6
You mean multiple by 25ppm/drop, right?
