For last six weeks, my alkalinity keeps going up. Can not get my alkalinity to go down. I check CL, PH and AL on daily basis. CL stays between o,5 to 1.5, PH always 8.0, AL- started out at 80 and stayed almost all summer, and now last 6 weeks stays at 120. I add Muratic acid to lower the ph, it will go down to 7.2 to 7.4, alkalinity will go down 110 but next day it will be 120 with PH going up to 7.4 or 7.6. I shock the pool to 20 to 22 PPM three times, but for one day result will stay good, next day AL will back to 110 or 120. Using K-2006 test kits since last 11 years.
The water is clear, I can see the drain at the bottom on 9 feet deep section but not as clear as it used to be.
Would appreciate very much any suggestions.
36 K Pool, Vinyl cover, 2 HP Hayward pump, S 244 T (300 LBS) sand filter.
