Moved from here.
So after battling the same issue with alkalinity amd well water and a quick Google search I found your post and I'm wondering if since this is such an old post if you did/didn't continue to struggle with your alkalinity on your well over time? I'm thinking it should balance out but wondering if I should plan to keep a steady supply of dry acid lol
Ok thanks for the tips. I have cya going now and am adding chlorine. I wondered if the green was iron. I used chlorine bleach to clean the surface and then rinsed the pool before refilling. I wonder if the bleach from cleaning turned the iron in the water green as it was filling.
As a general question, will I struggle to maintain water clarity with such high alkalinity water? I am wondering if others have been able to get clear water with over 300ppm alkalinity.
Thanks!
