I've had a fun time with opening my pool for the summer. Lots of algae to begin with. Shocked with Cal-hypo shock from Costco and it cleared up. Water was very cloudy after and I finally ordered a Taylor phosphate test kit. Reading was almost 3000 ppb with the normal range being 100-125ppb. Used PR-10000 from amazon which helped clear it up quickly. Pool was still a little cloudy. I checked the FC and TC. FC was around 1.5ppm while TC was about 6ppm. No algae in the pool but I shocked with 5 pouches of Chlorox xtrablue for my 30,000gallon pool. While working through this I installed a WaterGuru Sense 2, which is pretty cool btw. I noticed after shocking the water is completely clear now. The FC never went up even after shocking. I've gone through about 8-10 3" pucks of Trichlor and the FC stays at about .9 and my CYA levels are very low and not coming up. My ph is low 6.9-7 but my alkalinity is incredibly high 678! I tried aerating the water and the next day the water was 7.9ph. and the TA went down to 355. I added only about 4 cups of muriatic acid and the pool dropped all the way to 7.2ph. But the TA shot back up to 675. Kept aerating the water and the ph for the last 6 days has been a flat line 7.2-7.0. TA for those 6 days went from 675 >420>407>473>460 and today after adding 3 gallons of Natural Chemistry Instant Conditioner, because my CYA was very low, it went back up to 584. Aerating seems to have no effect on lowering the TA or raising the ph. My cya is now at 37 so hopefully the FC will start to even out. Meanwhile the pool water is crystal clear. Should I be worried about the very high TA and if yes what else can I do besides keeping going with the aerating. If not should I just add some soda ash to get the ph up and just let the TA ride?
