Hello all. About a week and a half ago I opened my 24' round by 54" deep above ground pool and started trying to balance it. Last week the local pool store tested my water and had me add 25 pounds of Maintain Pro alkalinity increase. Now my TA is at the top of the test limit, 240. My pH is sitting at 6.8. Stabilizer at 50. Free and Total Chlorine are at the top of the test limit with both at 10. Total Hardness is at 250. These results are from two separate tests using the Clorox testing kit and app. I then triple checked by testing with a different brand of strips and their colors align with these numbers.
Can I just add Muriatic acid in one spot at the farthest point from the return nozzle with the pump off, let it sit an hour and then restart the pump, until I get the TA down? Then I would raise the pH and TA together. I have JASCO Muriatic acid that is 20 Baume Hydrochloric acid 31.5% by weight. I am hoping someone could tell me if one gallon would be a good place to start. And if this method of bringing things back in balance will work.
I am not going to add any chlorine for a few days to let it drop back to a more balanced level.
