You can run a CH test and if it's fairly low you can use the cal-hypo for SLAMing the pool until the CH gets to between 300 & 400 ppm. While you don't need CH in a vinyl pool, it won't hurt anything as long as it doesn't get too high.
Thanks. Tested CH yesterday. It's 225.You can run a CH test and if it's fairly low you can use the cal-hypo for SLAMing the pool until the CH gets to between 300 & 400 ppm. While you don't need CH in a vinyl pool, it won't hurt anything as long as it doesn't get too high.
Thank you.Welcome!
She deserves a lot of credit. She did numerous tests, dosings, cleanings (skimming and brushing), and a filter change. And our daughter helped, too. She skimmed the surface a few times, and cleaned the main drain. It was definitely a team effort.He did a great job and the Wife of Gearhead deserves some credit too. I seem to remember a few times where you tested and dosed when he couldn't. And you've shown excellent patience throughout this ordeal. Kudos to you both.![]()
