First time above ground pool owner! Having issues with washout in the cove. We had one small spot and filled in the trench around the pool. Had a lot a of rain in the last few days and now have a larger spot in another area. Planning on digging the dirt back out we put in and installing a French drain. Has anyone done this? Did you have to drain the entire pool to fix the spots from washout? TIA!
