Rhanna
Haven't read everything but I installed a pool last summer with a SWG and heat pump with chiller.
1) SWG pool should have a higher chlorine level than the traditional chlorine pool. This is because the CYA is higher and the CYA is higher so the chlorine is protected more from the sun and the SWG doesn't have to run as much leading to a longer life. I haven't been in a traditional pool that follows the advice on this pool but I hear that most of the negative things people say about chlorine pools is because the balance is off (not following the advice here). And the effectiveness of chlorine is lower when the CYA is higher.
2) I'm surprised they have you installing a gas and heat pump. Seems like overkill to me. I went with a heat pump because I wanted a chiller and the electric rates where I live are good. I'm guess you'll end up using the chiller more than you expect given where you live and the size of the pool. I think it also depends on how often you plan on using your pool. If you are more of a weekend only type pool user then the gas heater is probably better but my family uses the pool almost everyday during the season (wife and son are both swimmers) another reason to run the heat pump to keep a consistent temp. I think you can get a separate chiller if you went with the gas heater (not 100% sure on that)
3) I guess it depends on SWG and heat pump but for my system the pump has to run at a higher speed while running the heat pump or it won't kick on. I can run a much slower speed and the SWG continues running.
4) I don't believe you can reduce your CYA level without draining and filling the pool, at least partially.
