- Aug 16, 2014
- 174
- Vinyl
- Autopilot Digital PPC4 (RC-52)
I have the loop loc off and the robot is running. I used Poly 60 at closing but do have algae. I usually don't run the robot but the water is clearer then in the past and I wanted to see if it still ran which it does.
I am having my SWG installed and wired over the weekend but between now and then should I test the water out of the gate? I have some leftover chemicals and shock so I am not sure if I should lay off doing anything until I test and post or add shock or other startup chemicals I typically used. Partially to get rid of them????
I know when I turn on the pump I will have some leaks and my intent is to do a power vacuum to waste to bring the water level down and really get great suction and get rid allot of the **** in the pool. So I think I answered my own question. Probably best to run pump, get water to level I want it, test water and then post? Good?
Since the SWG isn't installed I have the old cholorinator hooked up with no chemicals in it.
Appreciate the feedback
