hard time figuring this out. My pool runs at 28-30 psi. Even after cleaning filters. None of my pool jets are working, sometime after cleaning and I start it back up they work for a few minutes with a ton of bubbles and then they stop. My system has a infloor with popup, seem to work ok.
Also, takes awhile for the filter to prime and lead vac canister to fill and prime. Checked for leaks throughout and non detected. I’m thinking it’s a possible bad impeller or diffuser or blocked.
Thoughts?
Thoughts?
