Tony, we chose Lightstream glass tile that is $35 a square foot to purchase and was the same cost to install ($17.50 a linear foot). We opted to have an accent wall in all glass and found a complimentary ceramic tile for the waterline and every 5th tile, did a glass tile on the waterline. It saved is $4000 by not doing all glass at the waterline.
If you can swing it, do what you want, bc its not like paint color where you can just easily change it. I have read a lot where the glass tiles with the mesh have issues popping off bc they don't get a great bond to the thin set bc of the wire between the tile and the thin set esp if you pick a small tile and not to mention if the glass is see through, you will see the wire through the glass. $25 a square foot installed, which is $12.50 a linear foot, sounds about right and I wish ours had been that much as it would have saved us more money. But if you can swing it, do it, and have no regrets.
Thanks for the input Shantelly. Lightstream is the most beautiful tile out there. But I would still run across the same install costs. I've heard the same about mesh-backing mosaic tiles coming off, but I have two showers in my home and an entire wall with mosaic glass tiles with mesh-backing, and no issues in 4 years. But I know submerged in water is different. I still intend to use glass tiles everywhere. I just have to keep searching...I still have a 4-6 weeks before I need to worry about it.
Thanks Tony! All total the tile plus installation came to an extra $1,000. I was pretty happy with that! I love it!!
Only $1,000 extra?!?! Ugh...the difference between CA & GA....Enjoy it, because it is beautiful!
