Help with water test results
JDLRN
4
Louisiana
How to correct these water test.
TEST-----------------------RANGE-------------VALUE
1. Free Available Chlorine----1-4 ppm-----------10.74
2. Total Chlorine--------------1-4 ppm-----------10.74
3. Calcium Hardness----------200-500 ppm-----67
4. Total Alkalinity--------------80-120 ppm------29
5. Cyanuric Acid/Stabilizer----20-50-------------29
6. Phosphates-----------------0-125 ppb--------1304 --------- way high!
The best way is to start over with accurate testing. Pool store testing will fail you every time. We recommend either a TF-100/Series or Taylor K-2006C test kit as linked above. Trying to give advice on store testing is like throwing hand grenades in the dark.
Reactions: oledan and JDLRN
