Help with TDH calc.
Your System Curve is likely to be between B and C.
Get some vacuum and discharge pressure readings at:
RPM..........Feet of Head.
1,150.............
1,500.............
2,350.............
2,750.............
3,100.............
3,450.............
Super helpful! I appreciate that. Once I get home I will install that vacuum gauge into the correct port. Total rookie, newb move there. Whoops! So hypothetically if I get the optimal flow for adequate cleaning is there an advantage to programming different stages/speeds? I have 4 programming stages, system default. My old single speed ran at the max (3450?) full time and the advantage of this 3hp pump is I don't have to do that. So if say 1730 rpms was good why not run it 24/7 at that speed? Unless I am cleaning or flushing of course.
