I learned that my SWG wasn't generating chlorine below 50 degrees this winter, but I expected that once it warmed up, it would start again. However, that doesn't seem to be the case.
A week or two ago my chlorine was 0 so I added a gallon of liquid chlorine, which took it back where it needed to be. I checked it again recently and it's back to 0. Here's what my iAqualink tells me:
I contacted the pool company that built the pool last spring, and they said "That should go away if you add more salt to the pool." I thought I learned here that the salt shouldn't go away that much. The only way it leaves the pool is maybe through the overflow but there'd have to be a lot of it. Did I misunderstand?
Do I need to add salt, or is there something else I need to do?
Thanks.
Thanks.
