Yeah the CYA test always messes with my eyes too madyogi. My pool was exactly your clear green when I opened it two weeks ago. I know you have a lot of gallons to turnover, and have been doing awesome maintain the SLAM levels and the rest of the chemistry for a month. I'm a little perplexed that the water is still green after a month of SLAMing. One would think it would be at the tipping point of turquoise or aqua blue, or cloudy at least right about now after maintaining SLAM levels for so long.
I AM HOPING....Keyword hoping....That the bags over the next several days, get some of that gunk out of the water, so the chlorine can work more effectively in changing the color, turning the tides and killing off that stubborn algae.
I've read from other TFP members on here that its ok for humans to chemically swim in cloudy blue, because the algae is dead, and turned white, as long as the all the numbers are in proper range, and the water still isn't green. People can swim in SLAM shock levels within normal ranges without repercussions. My family and I have done it before with no ill effects.
Its really a personal choice, so If it were my kids, it was that hot, and they wanted to swim that bad ? Mandatory goggles, and shallow end only for water clarity and safety reasons.
I'm really hoping you get to a hazy blue by Sunday. Your lucky you can use your pool before Memorial Day.
I only open my pool in early may just to maintain it. Even if I had a few 90 degree days here which we just had, and even if I used my solar cover, I
won't see water temps above 72-76 degrees until late June, July 4th. So my season is really short. Right now my pool is a brisk 62 to 64 degrees.
(I secretly wish I could chop down my neighbors trees not only for more firewood, but sunlight on the pool, because we lose sun at 2 pm to shade.)
