Hi, I have a leak from my solar panels and have been trying to shut off the water flow to the roof, but despite pointing the "OFF" part of the Jandy valve (?) towards the pipe that leads up to the roof, water is still flowing/leaking. Can someone help confirm that the "OFF" is supposed to be pointed in the direction of #2 in the attached picture? (ignore the current position; I was testing to see if this position would stop the water flow but it did not)
#1 -- water from the filter
#2 -- water up to the roof
#3 -- water to the pool
#4 -- water down from the roof
Thank-you!!!
Thank-you!!!
