I am battling green algae and am preparing to SLAM. I just bought a FAS-DPD test kit, my PH is at 7.2 but my CYA is 100. The chlorine CYA chart says that slam is not recommend if the CYA is over 70. Question: Do I keep draining the pool to try and lower the CYA (and keep adding muricate acid to maintain the PH level) or go ahead and raise the FC (currently at 7) to the recommend levels with the CYA this high? What should I do? 20,000 gal gunite pool in south Texas. Hard water, high PH. lots of sun. thank you.
