Help with salt panel display
okiediver
56
Ft Myers FL
Went out to check my salt level and pool temp yesterday and the display is jacked up. Tried recalibration but no luck although it was changing numbers like it's supposed to. It's almost like the digital display decimal is off. Any clue?
Hello, I think it is set to metric system. try this..... press diagnostics button to display temperature, should be 1 press of the button. then flip the switch from auto to super chlorinate then back to auto. this is what toggles the readout from metric to standard. hopefully that will take care of the problem. Let us know if this helps. Have a good day !!
