I had to drain the pool because of high CYA. My question now pertains to my DE filter. After a normal backwash, I normally add 4 lbs of DE to replenish what is lost. When I drained the pool, I essentially did a long backwash (filter to waste draining through the bottom drain). I assume I need to add a corresponding increase of DE, but how much?
I see now that my filter has a capacity of 5 lbs so I'll start with 4lbs and go slowly from there.
