Help with pump motor
Stephen882
56
empire
The pump motor will have been installed 2 years this july. It’s already making a loud annoying noise. I’m thinking bearings need to be replaced. Problem is I’m having trouble finding what parts I need to fix it. Would like to have parts when I tear into it. Also what all would you have to replace when you change out the bearings. Pump is a waterway sd1702092960, sd-15-1n11cc, pk1150-6p. 1.5 hp.
S48aa11a79. Thanks for the help
I would suggest you call Inyopools and see what motor they might have to replace it. Typically the cost to replace bearings, etc approaches the cost of a new motor. But either way, you need a seal kit to use when your reinstall the motor.
