- Jul 12, 2021
- 86
- Plaster
- Pentair Intellichlor IC-40
I'm working on a project to redo my equipment pad. This is what it looked like to start. Issues included:
1. Heater didn't work but still wired up
2. SWG salt cell removed but control panel still in place and wired up
3. Polaris booster disconnected but still wired up
4. Waterfall pump was very loud and most parts were worn out
5. Equipment pad was 2 pre-formed slabs and were badly out of level (DE filter was sliding off back)
So, I disconnected the old heater, SWG, and Polaris booster, and hauled off, and I replaced everything on the old noisy waterfall pump. I also leveled the pads. That got me to here (I am also rebuilding the enclosure):
Over the last couple days, we pulled all the equipment off, removed the pre-formed slabs, and poured a new 9x3 slab (to fit the new Raypak heater sitting on the pallet in the leftmost position). That leads to my question... I was to fix the plumbing as we put everything back together, but am looking for some advice. Issues include:
1. Leak on one of the waterfall valves
2. Old skimmer and waterfall valves are not working well and can't be repaired
3. Plumbing looks like a spaghetti mess due to DE filter being to the right of the pool pump
It seems like ideally I would swap the DE filter and pool pump to eliminate all the extra runs. Would this be feasible with the current location of the incoming plumbing (from drain and skimmer)?
I'm also thinking I should swap out the blue valves for something serviceable. The Jandy NeverLube (4716) seem ideal, but they are very hard to find available. Are there good alternatives, or good sources I may be missing?
Thanks much! All the great advice here has really been terrific as I tackle this project.
