Help! I have spent soooo much time setting up my new Coleman 18 x 48 Power Steele Swim Vista II. Leveled the ground, set up pool, put it in place, put pavers centerd under each leg and dug them into the ground to be level. FINALLY starting to fill it up smooth out the wrinkles in the bottom about 2 inches of water then slowly going around adjusting the legs on the pavers to make them level, and now I'm noticing like half of the legs are not centered on the tiles any longer. Should I dig up the tiles and make them all perfectly centered or is itok as long as the leg is on the tile even if it's the edge? Thank you!
